Removing rubber feed rollers from planer
5/11/17
cabmaker
We need to change out the rubber rollers on our SAC planer. The rollers are supported by a six sided steel shaft
According to the manual you just remove a cap screw and washer then pull out the rubber rollers. There is also a larger metal element with two handles. This rotates but does not seem to pull out, even if we remove the little keeper that the pencil is pointing to.
Is there something else we need to do in order to expose these rubber rollers?
5/12/17       #2: Removing rubber feed rollers from p ...
Russ
It is call a snap ring, you will need a special set of snap ring pliers, some sets open and other close to when squeezed activate.
I hope that helps
Russ @ MR
5/12/17       #3: Removing rubber feed rollers from p ...
cabmaker
We have those special pliers and were able to remove the snap ring.
From there we were able to grab those black knobs and rotate the round steel part they are affixed to.
This, however, didn't appear to do anything. When we pull on them nothing happens. It is almost like there is another snap ring on the cutterhead somewhere.
Shouldn't this be able to pull straight out?
5/12/17       #4: Removing rubber feed rollers from p ...
Russ
The shaft is most likely milled to receive the snap ring, this holds the shaft in place, the ring is most likely pinched between the two pieces of metal, either way it must come off in order for you the get the shaft out. Be careful not to bend the ring out of shape or you will have to replace it. They sell snap ring pliers with different sized pins that are interchangeable with a small allen wrench.
Good luck
Russ @ MR
5/12/17       #5: Removing rubber feed rollers from p ...
Russ
Try Tapping on the shaft with a rubber mallet or small block of wood, it might be rusted from moisture.
5/12/17       #6: Removing rubber feed rollers from p ...
Russ
In your statement it says "remove cap screw" when you turn the counterclockwise screw does it move outward from where it is? Or does the shaft and handles move together?
5/12/17       #7: Removing rubber feed rollers from p ...
Kevin Jenness
It would appear that the bearing blocks and rollers are meant to slide out of the machine as a unit at which point you can pull the bearings and blocks off the shaft and replace the rollers. You may not need to remove the snap rings at all unless the bearings are shot.
Is there a grub screw or other fixing that holds the bearing block in the surrounding casting? I suspect there may be a groove around the circumference of the bearing block that allows the rotation you see, and removing a pin or screw that engages the groove would allow for removal. Is there a parts breakdown that illustrates how the blocks are fixed in place?
It appears you have some new rollers ready to go in. Can the supplier offer any guidance?
5/12/17       #8: Removing rubber feed rollers from p ...
JR Rutter
I have sometimes seen bearing supports like that where there are screws instead of the two handles that you need to back off the lock nut and screw in to slide the bearing assembly off of a shaft. You might try that...
5/12/17       #9: Removing rubber feed rollers from p ...
Bob
What model # planer is it? I would guess that the part with the handles has very fine threads on it and it will take a lot of turning before it is removed. The lock ring definitely is there to hold this piece in place.
5/12/17       #10: Removing rubber feed rollers from p ...
cabmaker
The planer is a SAC RS63
As you can see from the manual it says we should only have to remove the top bolt and end bolt and then it should slide off.
I attached a youtube video of how the metal donut on the end rotates. We also took the black knobs off so the donut would spin freely. We rotated it a lot of times and it spinned freely but did not appear to be threaded into position.
As the video shows we also tugged straight out but to no avail.
Any ideas?
View higher quality, full size image (3840 X 2160)
https://www.youtube.com/watch?v=GXZZLrmhxIs&feature=youtu.be
5/12/17       #11: Removing rubber feed rollers from p ...
Kevin Jenness
Judging by the written instructions and your video the top bolt holds the bearing block in the casting and the shaft is meant to be a slip fit in the bearing. I would guess that the shaft is binding in the bearing due to corrosion.
Try a shot of PB Blaster or 50/50 transmission fluid and acetone and let it soak overnight. Give the end of the shaft a tap with a mallet and wood block. If that fails, see if you can rig up a bearing puller using the threaded holes in the bearing block. A little heat judiciously applied might help to loosen things up.If there is access to the other end of the shaft, maybe you can drive it and the first bearing block out from that end. Use caution so as not to break the castings .
I think the snap ring is a red herring, it only needs to come out if you are replacing the bearing.
