water activated dowels
5/25/17
Chad Member
Hi,
We are switching over to a case clamp for assembly and I'm wanting to know the drying times using water activated dowels. How long does it need to stay in the clamp before taking out. Thank you!
5/26/17       #3: water activated dowels ...
Dan Cook
We put one in, staple in the back and hot melt it as soon as we put it in the clamp. By the time we put together another cabinet we take it out and repeat the process. Have never had any issues with it in over 20 years. We use regular dowel glue in the face holes and water in the edge holes. As soon as the glue and dowel come in contact the dowel swells and locks itself in. It does not have to be cured. That is the beauty of dowelling.
5/26/17       #4: water activated dowels ...
We do like Dan. Our cycle times are 2.5 to 3 minutes, plenty long enough in the clamp.
By the time the operator puts the hardware on the sides, injects the glue, knocks together the case, slides it into the clamp and hot melts the back --- more than enough time has elapsed to push the case that's in the clamp through and the next one in. Automated lines will clamp for maybe 30 seconds. That means, in theory, you can clamp well over a 100 cases a shift. Enough? Some one has to be doing the doors and drawers at that rate to keep up! We do mostly doweled drawers but in a separate drawer clamp that also works for dovetails.
