New panel saw blades
5/27/17
Finspat Member
Hello,
Been reading on this sight for over 10 years!
Have a situation, I run a slider saw, I have 30 years in panel processing experience.
Question for you folks, when you get a brand new blade, some times the new blade does not last very long like 15 4x8 3/4 Melamine, the I get it sharpened, then it will go 40 to 50 sheets!! Now this happens more often then not, like to hear your experience,
Kind Regards to all
Fins
5/28/17       #2: New panel saw blades ...
Guy Knight
What blades are you buying it sounds like the factory blades are not sharpened very well and that you have a good sharpener who puts the proper edge on them
5/29/17       #3: New panel saw blades ...
Finspat Member
We buy ghudo, some times they go for along time, this seem to be the case with all new blade, through out the years I have had this issue, nobody has this is, nobody?
For All those who have served our country
Thank you God bless
All the best
5/31/17       #4: New panel saw blades ...
For many years we've been running Leuco blades and never had that happen. Seems like the brand you are running should be good.
5/31/17       #5: New panel saw blades ...
Finspat Member
I am on my third set of blades, now it has cut a dozen sheets, and it's showing signs of the blade getting dull, now this is three sets
I have in the last year, replaced arbor assembly, also I did the same for the scoring saw assembly as well, just replaced belts.
Just getting nowhere, Tomorrow I am going to check run out with dail indicator , any ideas, I have had new blades cut good for a short period the get them sharpened , then they last a long time
Have a good day
Fins
5/31/17       #6: New panel saw blades ...
Gary
Rather than replacing on your saw, have you tried a different brand of blade as previously suggested?
6/1/17       #7: New panel saw blades ...
If the re-sharpened blades run well, it isn't the saw!
