cabinet build/face frame dados
6/29/17
Brett
Hi,
I'm looking to get some feedback on how we attach our face frames to cabinet. For years we have dadoed our face frames onto the cabinet box.
Cons to this method:
Framer has to dado face frames
Cnc does one more operation per end
Face frames do not always fit perfectly and the frame has to end up being run through the table saw to widen out dado
Pros:
The dado method completely squares up your box without measuring
Almost all shops we've seen do not dado frames onto boxes, they clamp and pocket drill. Looking for any feedback. See pic below for our joinery method. Thanks
View higher quality, full size image (2340 X 4160)
6/29/17       #2: cabinet build/face frame dados ...
Jim Clark
That's how I do mine.
To me, it looks higher quality than pocket
hole screws.
6/30/17       #3: cabinet build/face frame dados ...
John
Why not spline them with 1/8" and melamine glue? Just a thought.
6/30/17       #4: cabinet build/face frame dados ...
Mike Fuson
I do it a couple different ways depending upon the style and material used. If it's plywood sides I do it pretty much like you but I don't rabbet the panel, just 1/2" dado for the 1/2" ply to fit into. Most of my finished ends are raised panel and I pocket screw them flush with the edge of the face frame. Then cap the inside with prefinished ply, no pocket holes showing. All ends that butt up to other cabinets are ply that is pocket screwed.
