Tall cabinets
8/31/17
Daniel P
Need ideals I have a kitchen with 10' ceilings refrigerator opening is 48 wide plus lg pantry what would be best way to build these up that high I hate to double stack doors will be full overlay. Regular wall cabinets I can build 62" tall
8/31/17       #2: Tall cabinets ...
Gary Balcom
Daniel,
This may sound naive, but do they really need to be 10' high? Who's going to use these cabinets, Shaq? It seems pretty inconvenient for the owner to grab a ladder.
Why not leave some air above them? If you really need them to be 10', you can get other sheet goods such as MDF and melamine in 10' lengths.
8/31/17       #3: Tall cabinets ...
B
I would look for 10' sheet stock for the tall ends. Use toe boxes and make sure everything can be stood up if going to ceiling.
8/31/17       #4: Tall cabinets ...
Daniel P
I agree Gary but you know how some people are I would be scared of falling climbing up to them when I had to.
I will more and likely make the toe kick separate and add small trim
8/31/17       #5: Tall cabinets ...
Bob
I solved this type problem several years ago by making face frames for all my exposed ends and then using applied panels on the openings. If you have a toe kick height of 4"or more and build the cabinets 25"or less in depth and have the toe kick removable, the cabinet will stand up without hitting the ceiling.Example: Ceiling height 120" Toe kick 4" Cabinet height 116" Cabinet depth 25". The diagonal length of the side will be just under 119". Works every time. Does not work if cabinets are deeper than 25".
9/1/17       #6: Tall cabinets ...
Chris
What Bob said...Heres a face frame job we did last year...130" tall!
View higher quality, full size image (1809 X 1150)
9/3/17       #7: Tall cabinets ...
Mike Fuson
I've done this one time. We used paneled sides so we didn't need the 10' ply. We did the tall cabinets double stacked with a trim piece covering where they went together. One cabinet was to big to get to the kitchen and we had to assemble it standing up in place.
9/22/17       #8: Tall cabinets ...
Daniel Payne
Chris how in the world did you get that big of a cabinet in the house? They look good I see you did inset doors I will have to do full overlay Husband doesn't like seeing all that much stile showing.
