squaring door panels
9/21/17
Gary
How do those of you that make your own cabinet doors crosscut to length and rip to width your glued up door panels.
We currently crosscut them on a slider, which is a pain to rip on, and rip on a tablesaw which is a pain to crosscut on. I was thinking a small slider where the sliding table support does't project towards the operator so ripping is easier and crosscutting is a given, all on one machine.
9/21/17       #2: squaring door panels ...
You could go old school and make a crosscut sled for your table saw using the miter track.
We typically rip parallel on the ts and crosscut on the 12" sliding miter saw. It cuts 3/4 about 15" wide.
Occasionally we'll use the panel saw for really wide mdf wainscoting panels.
9/21/17       #3: squaring door panels ...
What kind of production are you talking about? How many per hour?
9/22/17       #4: squaring door panels ...
Gary
We average about 50 doors a week so not enough to invest in specialized equipment but enough to justify a small slider that can size both width and length at the same tool and also be used for other tasks. Our current slider leaves a lot to be desired and needs to be replaced anyway. We have a cnc so we don't need a full size slider anymore.
9/22/17       #5: squaring door panels ...
Why can't you rip on a slider? Use the sliding side.
9/22/17       #6: squaring door panels ...
Gary
I was talking to a slider salesman earlier today and that exact thought crossed my mind.
Our current slider isn't accurate enough to do longish rips with the slider.
9/23/17       #7: squaring door panels ...
Mike Fuson
Like Adam, sliding miter saw.
9/23/17       #8: squaring door panels ...
Gary
My desire is to rip and crosscut at one saw to eliminate handling and mileage.
9/23/17       #9: squaring door panels ...
Jim Herron
Vertical panel saw.
It takes up too little space, is too efficient, too safe, but it's biggest drawback is it doesn't resemble a table saw...
9/24/17       #10: squaring door panels ...
Dustin orth
I use our vertical panel saw on these all the time but keep the minimum size to 10" in either direction because of supports. When they are smaller we crosscut on either a jump saw or table saw with a crosscut sled. Our quantities are a few doors up to hundreds per job. Seriously look at a vertical saw as it will take your panel sizing to another level as well.
9/24/17       #11: squaring door panels ...
Karl E Brogger
We rip to width, then cross cut with either a sled, or just the t-square. I don't feel panels are hyper critical to make square.
We have a panel saw, but changing blades is a pain and we keep a hollow grind blade in the Striebig which isn't great for solid.
I'd think processing panels on a slider would be the easiest and simplest. I've thought about buying a small slider just for cross cutting glued up solid drawer parts. Our numbers are similar to yours, fifty(ish) doors a week and about the same number in drawers. Most of our doors are flat panel from ¼" material though, we don't do a ton of raised or solid panels.
