oliver 5385 sander
10/20/17
reynolds Member
I recently bought a new Oliver 5385 wide belt sander. The digital read out is only accurate to .005". Not good enough in my opinion. Does anyone have experience with these machines? Can the resolution be changed? Thanks
10/20/17       #2: oliver 5385 sander ...
Bill Member
Do you think you are going to be able to sand to a higher precision than that? I think you are going to be disappointed.
What are the drums on the machine? Rubber, Steel?
Grab a caliper, set it to .005 and look at the gap.
10/20/17       #3: oliver 5385 sander ...
Leo G
What is it that you are sanding that needs more precision than 5 thou?
10/20/17       #4: oliver 5385 sander ...
Alan F. Member
roughing up sanding sealer, but for that you need a more precise machine.
