Closet partition hang rail
11/9/17
al
I've done closets with the easy rail system where you make a 45 degree cut down about 8" and partition
notch hangs on a 45 degree rail. Richaleau has brackets that screw onto sides and these clip on their
hanger rail. I guess with this system your partition will be away from wall at top is this correct?
Any opinions on which system is better?
Thanks,
Al
11/9/17       #3: Closet partition hang rail ...
Bruce H
with hangers your panels are flush with the wall and you have adjustment up and down.
