Double Action Hinge
11/20/17
Pat
I built and installed a bunch of custom dog gates a few months ago and now the client would like me to convert one to swing both ways. I thought this would be simple, but the thickness of the gate is 1 3/4".
A Bommer hinge might work, but that thickness requires a 6" hinge, which is huge and ugly. Their specs say there's a minimum door height of 7', which I don't understand.
Any other ideas for hinges that swing both ways? They don't need to be spring loaded, but can be. I was thinking maybe Soss, but they don't appear to be double acting. I emailed Sugatsune and I'm awaiting their response.
Thanks,
Pat
View higher quality, full size image (3064 X 4592)
11/20/17       #2: Double Action Hinge ...
Alan F. Member
What about a Bommer 7400 or 7500
View larger image
Bommer
11/20/17       #3: Double Action Hinge ...
Pat
Thanks, Alan.
I thought about something like that, but I'm holding out for something that looks a little nicer. It's still an option if I can't find the right hinge, though.
11/21/17       #4: Double Action Hinge ...
Jarvis
Alibaba has a soss type hinge
Link
11/21/17       #5: Double Action Hinge ...
Pat
Thank Jarvis, but I only need 2. These people have a 500 piece minimum.
11/22/17       #6: Double Action Hinge ...
There might be a code issue with the gate opening over the stair side. Might be worth checking.
11/28/17       #7: Double Action Hinge ...
We use a lot of Bommer hinges, mostly on gates for behind the sales counter access. I've never seen this : "Their specs say there's a minimum door height of 7', which I don't understand." But then its been years since I looked at their instructions.
11/28/17       #8: Double Action Hinge ...
Pat
Thanks, Larry.
See link below which shows the minimum door height. The gate I need them for is about 42H x 35W and probably weighs about 30lbs. It needs to be held open by magnetic door stops. The 1 3/4" thickness requires me to use the 6" hinges. I don't want or need a lot of spring tension (none at all would be fine), but I know from past experience that the Bommer hinges need a certain amount of tension to maintain alignment and work properly. Have you ever used the 6" hinges for gates?
Thanks,
Pat
Bommer
11/28/17       #9: Double Action Hinge ...
Pat
Found these from Sugatsune. Still big at 7" tall, but a little less bulky and commercial looking. Anyone tried them?
Thanks,
Pat
Sugatsune double acting spring hinge
11/28/17       #10: Double Action Hinge ...
Mark V.
If I had to do this, I would be looking at pivot door hinges and cafe door hinges.
Mark
