True32 and beaded inset face frame cabinets
1/9/18
Matthew Brewster Member
I've recently put a bunch of frameless cabinets, full overlay doors and drawers together with Festool's LR32 system. I was drawn to it because of it's speed, simplicity and the fact that it reduces, I feel, the potential for error (doesn't eliminate, just reduces). I prefer, however the look of beaded inset door and drawer fronts on FF cabinets and I'd like to incorporate the same (True32, Process32, KISS, etc.) process.
I've done a lot of research, especially on True32 and just can't seem to get it through my thick head - why do the drawers and drawer fronts have to be a multiple of 32 (minus reveal) for this type of construction if you're not going to be mounting the hardware to the sides of the cabinet? My first guess is that I'm reading it wrong and won't be able to use a 32mm system with face frames.
To put it simply: How can a 32mm system help me with beaded inset, face frame cabinets?
Thanks in advance for any comments.
1/9/18       #2: True32 and beaded inset face frame ...
Bruce H
It can't... 32mm cabinets gain efficiency with the standardization of hardware placement and flat panel processing. The parts are on 32mm increments because line drilled holes are on the same centers. Door and drawer fronts fit between those holes.
Once CNC enters the picture you can have the same cabinet in any size, with any size front and the standardization of hardware placement. I drill all of my hinges 94.5mm from each end regardless of size.
Your analogy it like comparing apples and zucchini.
1/10/18       #4: True32 and beaded inset face frame ...
If you are geared up for a 32mm system, it makes sense to build all of your boxes to the 32mm system.
You need to make all of your boxes, shelves, drawers shorter by your face frame thickness.
If you can think of face frames as really thick edge banding it gets you going in the right direction.
The #1 reason for using a 32mm system is its metric. You will be defeating the purpose a bit by using inch face frames.
Those dual metric/inch tapes are so last century.
1/11/18       #5: True32 and beaded inset face frame ...
Paul S
Matt, I used to build cabinets like that....problem I ran into was the limited DB layouts i could come up with using the 32mm system and be fighting with the decorators on drawer size. Then I went frameless and used heavy endpanels. That seemed to please most clients. Today its very few restrictions if any with a CNC.
1/14/18       #7: True32 and beaded inset face frame ...
Matt Member
Sorry it's taken a while for me to get back. I appreciate the comments and information.
Bruce: Got it on the door and drawer fronts, thanks.
Adam: Thinking of it in terms of edge banding helps, thanks.
Paul: Sorry but what do you mean by "heavy" end panels?
Thanks again for the comments.
Matt
