Prefinishing Panel in Cabinet doors question
2/4/18
Ron Member
I have always wondered how pre-finishing door panels would work out if your spray finishing. Finishing the pane would be real easy.. but after the glue up .. you would have to mask everything in order to spray the frame .. how is this efficient ? I could see pre-gluing 3 sides and finishing that separately from the 4th side .. but then gluing it all together would create possible problems with the final 2 joints. How is this accomplished, I would sure like to know the steps.
2/4/18       #3: Prefinishing Panel in Cabinet doors ...
MarkB Member
The way the big commercial shops feeding the home centers do it is by prefinishing the panels and the sticking. The copes are made on finished sticking and the door us assembled fully prefinished with hideous joints at the rails and stiles.
We will pre-stain our entire panel and spray a light seal coat on the panel raise when possible prior to assembly the when the door is assembled we will final stain avoiding the panel as best as possible. The finish as normal. This way the portion of the panel thats in the groove has stain and some finish on it.
Pigmented changes things.
2/5/18       #4: Prefinishing Panel in Cabinet doors ...
Jim Clark  Member
Website: http://s51.photobucket.com/albums/f386/jcquack/Fur...
I stain and spray sealer on the panel and
stain the inside profile of the rail and stile.
Then assemble the door, sand the face of the frame and finish cutting to size, stain and spray sealer on all of it, including the panel, then the final finish.
It helps to have the panel a little lower than
the frame for sanding the frame once assembled.
2/5/18       #5: Prefinishing Panel in Cabinet doors ...
The way MarkB does it. I finish the panel with a sealer coat first then proceed as usual you end up with one extra coat of sealer on the panel that isn't noticed at all. I wouldn't worry about it and if the door has no stain just clear coat even better. I'm just a one man shop if that makes a difference.
