Hello all,
This is a good, healthy debate here! It looks like you've all been doing your research to find the best connector solution for your operations. I thought I'd chime in here and offer a bit of input.
Just for your own comparisons, the list price of the Cabineo 8 or 12 connectors is $0.33 each. The tips on the Cabineo bolts are indeed blunt because they are designed to screw into the 5mm shelf pin holes that are drilled into the corresponding upright. They are not designed to self-tap like a Confirmat screw.
I tend to agree with Dave L in some respects. If you've already invested in edge boring machinery with case clamps, and that system works well for your operation whether with or without dowels, then the Cabineo argument isn't as strong. That being said, if you're looking to free up floor space, your dedicated machinery needs replacing and it's time to re-evaluate, you need to flat-pack your components, do closet- or store fixture work, etc., then it's certainly worth a closer look.
Cabineo is a VERY strong connector to consider if a shop owner is using only a CNC router, but does not have edge boring capability or the floor space to invest in a dowel/case clamp line.
In response to the Rafix comparison, the Cabineo 12 clamps with 200 pounds of force and has 200 pounds of sheer strength per connector. The versions of the Rafix without the outrigger piece sometimes have a tendency to twist in their pocket, whereas the Cabineo will not. And since the Cabineo is a one-piece connector, it is able to allow true flat-packed components with all hardware pre-installed (as opposed to either Rafix or Minifix).
The Cabineo also works well for closets since you are able to add shelving using a top-load installation method. In terms of the aesthetics, cover caps in various colors are available, or the shelf/top/bottom may be flipped over when it's above or below eye-level as needed (as Mark B. mentions).
Please contact us if anyone would like a free Cabineo sample to evaluate on your own.
* Of course, for invisible connectors, Lamello offers the P-System series too.
