Univer power feeder oil change
2/26/18
Michael Member
Sorry to bust in on here but does anyone have any idea what oil is used for a Univer/Pertici power feeder?
2/26/18       #2: Univer power feeder oil change ...
MarkB Member
More than likely 80-90/weight gear oil like every other. You could probably put vegetable oil, 5w30, chainsaw bar oil, Lucas, not anything in it and itd run forever.
Anything that would run in thr rear end of a daily driver would have to run for a lifetime in a low rpm feeder.
2/27/18       #3: Univer power feeder oil change ...
Michael Member
Makes sense! It's just a gearbox, right.
Thank you.
2/27/18       #4: Univer power feeder oil change ...
MarkB Member
There was a recent post here somewhere about the same issue. I just run straight Lucas in mine. It's pretty much compatible across the board with any gear oil out there and has incredible climbing properties so on anything other than a manufacturer specified high dollar machine that's what i run.
