help with Casadei edgebander K320
3/28/18
alain  Member
Website: http://www.bisarowoodworking.com
I just got this 2006 small edgebander K320 .
unfortunately it was not very well maintained ... I got it running pretty good but the end trimmer is not working properly , has a guillotine type trimmer , it trims the front well but not the back , it follows the panel but does not cut ...I believe several small bander use this device so hoping someone knows how to fix it ...
3/28/18       #3: help with Casadei edgebander K320 ...
alain  Member
picture of the unit
View higher quality, full size image (2765 X 2074)
3/30/18       #4: help with Casadei edgebander K320 ...
The first thing I would check is the two micro switches that trigger the guillotine. If you are handy with electronics check for signs that the switches are working with a multimeter. Or do as I do and fiddle with the switch and spray with contact cleaner (power off).
4/4/18       #5: help with Casadei edgebander K320 ...
Daryl
I have the same edgebander and had the same problem. I fought it for a few years until the main plastic tee fitting on top of the gilotine broke in half, I replaced that fitting and it fixed the problem. I found that the tee had a small Crack and that wasn't allowing enough pressure to the air cylinder.
