Edge bander cleaning
10/31/18
I was wondering what is recommended by others to clean the rubber pads on the feed chain on an edgebander? The pads are leaving marks on the material being banded. The pieces have to be wiped which is a bit of a pain when maybe it isn’t necessary?
11/1/18       #3: Edge bander cleaning ...
Larry Schweitzer
What are you getting on the pads that is being transferred to the work?
11/3/18       #4: Edge bander cleaning ...
dustmaker1
Same question as Larry. What is getting on pads in the first place? We have had, dust from not being used for a while, easily cleaned off.
Grease, probably from over greasing feed chain, dropping between pads when going around bottom of machine. Turned out feed chain was bumping frame at bottom of travel and rubbing grease on pads.
We had the gear box for pressure station leek oil on to chain and subsequently onto pads until we discovered the problem.
Pads themselves should not be leaving anything to clean unless they rubber is breaking down or something.
Paul R
11/7/18       #5: Edge bander cleaning ...
Derrek
Denatured alcohol
