Carbide insert for raised panel cutter
1/17/19
Doug Conti Member
I have a insert cutter head for making raised panels. It has a back cutter and end cutter with it as well. I have been trying to identify the manufacturer so I can purchase some new inserts. On the insert it has the following RT1014i stamped on it. I have attached a picture of it. ANybody have any ideas?
1/17/19       #2: Carbide insert for raised panel cut ...
geoffrey grice Member
Its a possibility that you do not have to get the exact maker. the hole pattern in the cutter could be a more universal pattern. measure center to center and from bottom and call around and find someone using that same blank. I bet there is not that many people making blanks
1/18/19       #3: Carbide insert for raised panel cut ...
My tool sharpener is making inserts and trying to compete with the tool manufacturer prices. Send me a note if you would like their information.
My tool maker Great Lakes tooling I am sure could duplicate them for you. The issue would be you would need to buy 12 to get a decent price. If it is a standard tool you could likely get lower volumes cheaper.
You can also get them sharpened. There are down sides to it but it is an option.
1/18/19       #4: Carbide insert for raised panel cut ...
DOUGLAS P CONTI Member
I have sent it to great lakes already, I do believe that they were the ones to make the body but I am afraid that it is way out of date. If it is going to cost more to have them made (not to mention the time) then it is to replace them with tooling that is readily availible then it really won't be worth it. Typically it cost about $100 to replace inserts on cope and stick, a little bit more for the raised panel cutters with the edge and back cutter, but I have had success sharpening the panel cutters because they are not as critical as the cope and stick.
1/24/19       #5: Carbide insert for raised panel cut ...
Brent Member
Website: http://www.youtube.com/c/DovetailTimberworks
If you want to throw enough money at it I'm sure someone will make a replacement for you, but I expect it'll be expensive. Depending on how much panel raising you do, I would consider a head that takes replaceable HSS knives that you can touch up yourself, and will take an infinite variety of profiles. The problem with the carbide inserts style is if you ever want to do a profile that deviates too much from what your head was designed for, you often can't because either the backer is exposed, or there isn't enough backing and the thin, brittle knife can snap. I now use these heads that can do any profile and can be tipped in carbide if needed for longer run times.
http://whitehill.tools/catalogue/#page=75
