Holzher edgebanding cuttters
9/25/19
D Conti Member
I have a 2008 Holzher 1308 edgebander that I purchased used. The top cutter would not properly adjust and when I removed the insert cutter head I found it to be the wrong over all diameter (it was 54 mm and should have been 50mm). I had the orginal diamond cutter and installed that one and it has been doing fine, although it is now a little bit dull. I want to replace it with a insert head that can do a 3mill radius. I believe Leuco makes one model 1721240, 1721239. Is this correct and are there any other manufacturers that make this type of head?
9/25/19       #2: Holzher edgebanding cuttters ...
Bill Member
I would call lakeside industrial supply.
http://www.lakesideindustrial.com/
I would also call Pettit Technical service they may be able to get you a used one.
814-432-3011
