Any Info on Using an Altendorf Duplex Miter Gauge?
1/20/20
Ken Member
So I picked up this toy recently and having a bit of trouble with setup. If I'm set at 90 degrees the ruler can be set accurately, say 12". Moving the gauge to 45 degrees and now the measurement is off due to the pivot point. I'm trying to figure out if there's an angle compensation trick to this. The second and third photo shows a ruler with angles on it but it's not making sense since the stop has the line marked on it. Also the 8" mark on the ruler is a different color so it must mean something. Would be nice to have the owner’s manual for this accessory. Any thoughts?
View higher quality, full size image (1080 X 810)
1/20/20       #3: Any Info on Using an Altendorf Dupl ...
Ken Member
Nevermind, found a manual online.
1/20/20       #5: Any Info on Using an Altendorf Dupl ...
Michael W. Taillon  Member
Can you post the link for the manual you found online? It 's interesting to learn about these tools - I'm interested.
1/26/20       #7: Any Info on Using an Altendorf Dupl ...
Ken Member
https://www.daltonswadkin.com/wp-content/uploads/2014/04/Altendorf-F45-F45-Elmo-Ma
nual.pdf
1/27/20       #8: Any Info on Using an Altendorf Dupl ...
Thanks for sharing the manual Ken.
    • Country Saw & Knife
    • Anver Corporation
    • Sandman Products
    • Salice America Inc.
    • J&P Machines
    • Supergrit Abrasives
    • Doucet Machineries Inc.
    • Charles G.G. Schmidt Co.
