Tandem wide drawers
2/3/20
Bob  Member
Anybody doing 36 in wide drawers with Blum tandems?
Are the stabilizers necessary?
2/4/20       #3: Tandem wide drawers ...
Family Man
Yes, a couple a week for a decade. No callbacks at all. Zero. No stabilizers used.
2/4/20       #4: Tandem wide drawers ...
I don't use stabilizers. Not sure if my drawer boxes reached 36" wide, but they are close. I have lots and lots of 32" drawer boxes out there without issues.
2/4/20       #5: Tandem wide drawers ...
Stewart Member
I agree with the others. We've done dots of wide drawers without having to use stabilizers. No issues at all. The only time I find I have to use stabilizers is when I'm doing a wide drawer that's only 12" deep. Then the stabilizer bar becomes necessary to keep the drawer in synch with itself as it opens and closes.
2/4/20       #6: Tandem wide drawers ...
Our rule is any opening over 32" gets the stabilizer and we bump up to a 569 slide instead of the 563.
Probably overkill, but I charge for it.
2/4/20       #7: Tandem wide drawers ...
I think Blum recommends the stabilizer on any drawer over 24". That seems asinine.
2/4/20       #8: Tandem wide drawers ...
Me. Blum likes to sell you things you don’t need. I’ve never used one stabiliser. Every few years when looking thru their catalog I notice some new item that nobody uses. Over the years I’ve called our supplier Atlantic plywood and they have never ordered one of them before.
2/5/20       #9: Tandem wide drawers ...
Matt Calnen
Personally I think they are to wonky to just use tandoms. That was one of the reasons I am starting to use the Grass dynapro. Much better rack resistance, and easy to add the stabilizer bar if needed
2/11/20       #10: Tandem wide drawers ...
Pdub
We use the tandems as standard, but change to the Grass 3D on 32" and wider. I like the rack and pinion for wider drawers. The Grass are MUCH easier than the Movento.
Tandems work, but they're a little wonkey feeling to me.
    • Limtech Industries, Inc.
    • Denray Machine
    • Cabinet Pro
    • Impact Search and Placement
    • RT Machine Co.
