Hinges??
7/27/20
Jay
Website: http://jayscustomcabinets.com
Customer wants to use cabinet doors to create an entry into their walk in pantry. Basically a pantry unit would be against the wall, with a pair of doors next to it. It would appear to be another pantry cabinet, but the doors would push in, to create a walk through to the walk in pantry. Is there a hinge that would allow for a full overlay look, but instead of the doors opening out, they would open in. Any suggestions would be appreciated. Thank you....
7/27/20       #2: Hinges?? ...
Alan F. Member
You could play offsetting a piano hinge with part on the end and part on the door in the closed position so the door hangs over the end but I have no idea what would keep the doors "closed" in the closed position
You might be able to find a center pivot hinge with enough offset to have an overlay and still open in. Not sure other than Rixson where to look.
8/22/20       #3: Hinges?? ...
Doug Member
Do you have the JNF Coplan hinges available in your area? We've used them a number of times, otherwise try soss hinges
Mardeco Adjustable Hinge
    • Sandman Products
    • Template Services
    • O'Shea Lumber Company
      Merchants of Fine Woods
    • Better Vacuum Cups, Inc.
    • RT Machine Co.
    • Wood Doctor's Rx, LLC
    • Laguna Tools
