Cope and stick profile
8/1/20
Andrew Prather Member
Website: http://www.joryworkshop.com
Dose anyone know who sells these cope and stick cutters with this profile?? My door supplier sells these doors and the joints are supper strong. The tenons are tapered and rounded so the glue pushes trough the joint.
View higher quality, full size image (1209 X 1208)
8/1/20       #2: Cope and stick profile ...
You just have talk to your tooling guy and order them that way, it may cost a little more, but you have what you want.
I have a bunch of rounded ones all made by FS tool.
View higher quality, full size image (640 X 571)
8/1/20       #3: Cope and stick profile ...
I just wanted to mention that it is all insert tooling so you can get them to pretty much do any shape you need.
I got thinking and I also have some Royce as well.
8/2/20       #4: Cope and stick profile ...
Scott,
Thanks! Royce Air has some profiles! I will check out FS tool as well!
8/4/20       #5: Cope and stick profile ...
Hen Bob Member
I had a set made a few months ago to match a profile from the door supplier. Well worth the $
10/11/20       #6: Cope and stick profile ...
Chris Payne
Byrd tools will fix you up
    • Limtech Industries, Inc.
    • Denray Machine
    • Cabinet Pro
    • Impact Search and Placement
    • RT Machine Co.
