Computer Aided Design
Subject: Re: Microvellum help
Microvellum help
8/7/13
Cody
I just started to use Microvellum on a daily basis for some production work and im trying to learn how to do some custom things using it, but when i send it to the router, my lead in's are messed up. For example if i have a 12", 1/2" deep cut it takes 6" of that cut to get to final depth. Can anyone help?
8/9/13       #3: Microvellum help ...
Joe
Website: http://berardidesign.com
What kind of machine token are you using for this operation?
If you are using a PLINE. It sounds like its treating the first route as the lead in. If that is the case I am assuming that you added this "Route" by hand and didn't include a lead-in to the polyline. If you have no specifically instructed it to have a lead-in then you must use the "Add Lead-In to Polyline" command. If you're using V67 go to parts tab->Routing Tools->Additional Routing Tools->Add Lead In to Polyline. If you are using V7 then go to Work Orders Gear->Hit the Arrow next to edit nest->Click Single Part Editor->Route Editing Tools->Add Lead In to Polyline. Then follow the command prompts. One other thing to check if you are using the polyline machine token is the additional [Options]. You'll want to enter something like this "0;0;1;1;0" in parameter 4 (without the quotes).
If you are not using the PLINE token then you most likely have a lead-in problem in your tool file.
Hope that helps.
8/9/13       #4: Microvellum help ...
Cody
Yes that did help thank you very much.
