Computer Aided Design
Subject: Re: Autocad 2004
Autocad 2004
1/20/14
Ronald Seto  Member
How can I convert dwg files to pdf format for publishing.
1/21/14       #2: Autocad 2004 ...
Jason  Member
Website: woodproacademy.com
Questions to get started ...
1] Do you have AutoCAD installed on your computer?
2] Do you a PDF application installed on your computer?
If you have both then it's fairly simple.
Open your CAD files and print/publish them to your PDF application. The PDF application works just like a printer but instead of paper copy you get a digital copy. If you need to be able to scale the drawings the you'll need to have a basic understanding of scale in relation to paper space layouts. If it doesn't matter then printing just like any other document should be fine.
If you do not have both there is not much you can do on your own. If this is a one time need you could download and install trial versions of AutoCAD or Volo View. You also could hire someone (like me) to handle your files for you.
This may help as well ... http://www.youtube.com/watch?v=RFqPnAfRiTQ
1/21/14       #3: Autocad 2004 ...
Dave Edgerton  Member
You need to install a pdf virtual printer like bullzip pdf printer. I downloaded it 5 years ago and use it all the time.
1/28/14       #4: Autocad 2004 ...
Dan
Since Acad 2010 or 2011, Autocad has had the ability to print directly to a pdf. If you are using an earlier version you will need a pdf utility such as pdf creator.
2/8/14       #5: Autocad 2004 ...
Paul
I often use Autodesk truview. I feel it does a better job at batching pdf plots than Autocad does. It also can be used to downconvert newer Autocad files for use by older versions. And, it's free.
Autodesk
2/13/14       #6: Autocad 2004 ...
Michael Member
Download and install Autodesk Design Review.
When you print your drawing, print to .dwf format.
Open the file with Autodesk Design Review and then print to PDF from that. Great program for adding notes to drawings as well.
Install on AD Design Review can be tough as you can get errors upon install. Search the web for the solution. I've had to do it several times but forget what I did to solve the problem but the solution is out there.
We are still running Windows XP.
3/14/14       #7: Autocad 2004 ...
owen t Member
I use PrimoPDF, a free program, which converts drawings to a pdf file. Install PrimoPDF and it appears as a choice of printer. I would never send an Autocad dwg or dxf file to a customer or a supplier or anyone. If they want a drawing file, they get a pdf file from me - no data. Speaking of printing, I used to use Kinkos, but now use Staples. I email the drawing pdf file to them and it’s done in a couple of hours, cheap and free delivery if it’s $20 or something like that, available 18x24, 24x36, and 36x48.
