Computer Aided Design
Subject: Re: Vcarve and Biesse
Vcarve and Biesse
4/17/14
Randy Member
Has anyone been able to run vcarve pro on a Biesse Klever. If so what did you have to alter in the post processor. Tech support with vcarve told me that they would not be able to help me past there stock biesse post processor.
4/19/14       #2: Vcarve and Biesse ...
yaakov katz
cix? cid ? or iso?
4/19/14       #3: Vcarve and Biesse ...
Randy Member
iso
4/19/14       #4: Vcarve and Biesse ...
yaakov katz
why??
its clever machine ,no 5 axis why not pass the BSW?
iso its very complex and now with the nulti center plc becomw worth
10/19/14       #5: Vcarve and Biesse ...
Alien Member
I really wanted to use Vcarve with my biesse but in reality I found my machine would only handle 1000 lines of code and the way they handle arcs with small segment line the 1000 lines ate up pretty quick. Also they did not want to make any effort at all to help me with a tool file at all. so I would guess the support would be the same way.
11/3/14       #6: Vcarve and Biesse ...
jack
most of the issue lies around the multi center and the first work begin line needing to be modified. Ask Biesse if they have the converter you need to convert the standard code into the correct code to run the machine.
11/3/14       #7: Vcarve and Biesse ...
yaakov
file/seting/machining opertiion
in the butom you can modify the max machining oper.
if you still need write
pp from vcrave to cix(bsw ) send me mail
2/13/20       #8: Vcarve and Biesse ...
Courtney
I have created a perfectly working post for BIESSE rover machines. Contact me and I can get you setup
3/23/20       #10: Vcarve and Biesse ...
dh_dave Member
Running Vcarve on a 2016 Biesse Klever.
Recently I got in contact with Courtney he has a written a working Post Processor that works with Vectric and Vcarve Pro, he provides the Post and support for a fixed fee to make it work with Rover and Klever Maschines
