Computer Aided Design
Subject: Re: shelf boring linked to hinge boring in CV?
6/14/14
Derek
this is a CabinetVision question.
When creating angled shoe shelves, I need to turn off the feature "bore only required holes" which typically places 7 holes per shelf, and instead use the feature "bore all holes" in order to get a full line bore pattern from the top to the bottom of the panel. When I do this, it turns off the hinge plate holes which we have activated as "inline". I presume this has something to do with the program thinking I want to use the vertical line bore holes for hinge plates, which I do not. Is there a way to deactivate this association?
Derek
6/14/14       #2: shelf boring linked to hinge boring ...
cabinetmaker
I have been setting up a construction method lately of exactly what I want to in a case by case basis utilizing both the materials and construction methods. This has helped a lot in things like file mail slots in the bottom of wall cabinets where there are doors on top.
In your case, I have made sure that I told CV to start the holes @ 2" from the bottom edge and stop @ 6" from the top edge, boring all holes, or openings.
