Computer Aided Design
Subject: Re: CV UCS help
CV UCS help
9/8/14
Derek S.
I wouldn't ask this except that I know this is probably a super easy UCS for someone smarter than me...
Can I get someone to write a UCS that rotates my unfinished backs 90 degrees?
Thanks,
Derek
9/8/14       #2: CV UCS help ...
steve Member
Is it for grain orientation, what are you trying to do?
9/8/14       #3: CV UCS help ...
Derek S.
Yes, grain orientation. We've had to change how our Nesting software receives information from CV. Used to be we exported information via cutlist (Ascii file?) and now we're exporting via DXF so that we can export shapes. But the DXF is not orienting the backs correctly and they need to be rotated. All the other parts are oriented correctly.
Derek
9/8/14       #4: CV UCS help ...
John McGinnis Member
;Rotates UB 90 Degrees
For each UB Part
AZ = 90
[copy and paste that directly into your UCS]
If you want it to go the other way put a minus sign "-" in front of 90.
9/9/14       #5: CV UCS help ...
Darren Member
Derek,
Is your Assembly Construction - unfinished back grain direction set correctly.
View higher quality, full size image (631 X 516)
9/9/14       #6: CV UCS help ...
Derek S.
Darren,
Yes, our backs are setup correctly. And the cutlist is orienting the backs correctly, and we've run via ascii file correctly for years. But for some reason it would appear that the DXF information just for the backs isn't being exported correctly. At least that's the assumption I'm going on right now, we'll see if this fixes the problem. Thanks John, by the way, for the UCS. I'll try it right now.
Derek
