Computer Aided Design
Subject: Re: operating system for SCM
10/30/14
scott
I am running a SCM pratix and the operating system is windows XP, all the new software requires newer operating systems. I was wondering if xilog will work with Windows 8. I would like to up grade the operating system. Thank for any help?
10/30/14       #2: operating system for SCM ...
cabinetmaker
Call scmi. Do not do this on your own.
11/2/14       #3: operating system for SCM ...
Gary B
I second that. Don't mess with your machines controller, unless you want an expensive paperweight! There is nothin wrong with windows XP for a machine controller. I bought a brand new Weeke this April, and it has XP (embedded). And you really shouldn't add any extra software to this controller, it's not worth it. That computer has more than enough to do. Add another shop computer if you have to.
11/2/14       #4: operating system for SCM ...
cabinetmaker
What we are saying is that XP Pro is very stable and the factories are continuing to use it because of that fact. The only operation for our pc running our cnc router is to receive operating files from the office that are in the specific format it requires to cut and drill.
The only time that we go online with it, is with tech support, through a documented "Webex" session.
Yes, your pc's in the office should be up to date and running the current operating software, we are running Windows 7 Pro ourselves. Just fyi, we have 6 pc's in the office and we all are capable in drawing in our design software. All of the drawing files are saved on our network and the operator fetches the file and runs it on the one designated pc in the office that sends cut files to the cnc pc via the network. This pc also very rarely surfs the net, but is running on Windows 7 Pro also.
I hope this helps.
11/2/14       #5: operating system for SCM ...
scott
Thanks for the input all. The computer for the cnc is dedicated to just the cnc. I was looking at getting some new software and the requirements for that software is windows 7 or higher so was wondering how I could load that on to the computer? The software I was looking at is Mozaik. I was assuming that a copy of that would have to be on the cnc computer?
11/2/14       #6: operating system for SCM ...
cabinetmaker
Read up on woodweb and the software you name and the frustration of others, before you decide. @ one point I was on your shoes, but I had an investment in one software, so I went with it.
If you look @ some of the posts by James McGrew and others, thye talk about cam software and writing posts that generate the code for your cnc to cut. "Router Bob" of Laguna Tools does a great job of explaining this and does a lot of his design work on a Mac notebook in his you tube videos and takes a thumb drive to the cnc router and imports his g code or cut files. You can do the same.
James McGrew gives some great advice of drawing in Vectric and posting to his camaster. So, essentially, you need the design software, a cam package and the post to your machine from your manufacturer. The post will send a certain file to the controller/pc of the Pratix and it will then cut the files.
KCD, Cabinetvision, Moziak, Cabinetpro and a host of others have their own cam, or post and this will greatly help you.
