Computer Aided Design
Subject: Re: Output to Sketchup
Output to Sketchup
3/3/15
karl  Member
Website: http://www.benchwerks.com
I am thinking of moving back to Ecabs after a time with Mozaik. While I like Mozaik well enough - their output to Sketchup feature is fantastic, for instance - I'm not convinced I need to spend the money every month to keep it up. I am a small shop with no automation, so advanced software is overkill - beyond spreadsheets and project management, I need simple layout and rendering.
So a couple questions for current Ecabs users, as its been a while since I've used it:
1. Ecabs used to be tough on resources - can I efficiently run it on a 15 inch HP laptop, (I3, 1.8 GHz, 8 GB RAM)?
2. Does it have an output to sketchup feature these days?
3. Can I run it on a parallels-type overlay on a Mac, or do I need to run it on bootcamp?
Thanks in advance.
Karl
3/5/15       #3: Output to Sketchup ...
I dont really understand the output to sketchup part but just incase you werent aware, there is a great plugin for SU called cabinetsense software. Its a paid monthly plugin that I believe you can start/stop as needed (its 30/mo). It does complete dynamic components, all boxes, drawers, slides, hinges, FF or frameless, and so on. Outputs full cutlists, BOM, door and drawer schedules.
I use it in conjuction with SUpro and do raytrace rendering in Podium (purchased plugin). I find that for the 30/mo I have all I need. Cabinetsense also has CNC output if needed.
No affiliation just letting you know that if your using SU and like it, there is an option there.
3/5/15       #4: Output to Sketchup ...
Karl
Hey thanks Mark, I'll check that out.
3/11/15       #5: Output to Sketchup ...
Ditto on CabinetSense
