Computer Aided Design
Subject: Re: AlphaCam V5 Multidrill
5/11/15
Matt Middleton
Website: http://stidhamcabinet.com
I'm currently runny alpha-v5 june 27 2005. We had some issues with the pc it was on and I had to setup another pc to run it. When I try to use the multi drilling it says select machine configuration. Our machine configuration isn't shown. What file type am I looking for to make this work? I have a bitmap image and an add file. I noticed the others in the licomdat folder have a data file. Is this what I need created to make this work correctly? If so how do I create it. I do have a post and it works for routing but the multi drilling doesn't. Thanks
5/12/15       #2: AlphaCam V5 Multidrill ...
Wow. That was a long time ago. If my memory is correct, it might be a .mdb file. If you look through your files in explorer, it will have the same name as the bmp file, which is the image file for your drill block config. Good luck.
5/12/15       #3: AlphaCam V5 Multidrill ...
Matt Middleton
Thanks for the response. We obviously didn't keep up with our support. Have been using microvellum for almost everything but it is nice to have alphacam for some of the custom pieces. It looks like I have an add, bitmap,cfg, data and microsoft access database file. Here is another question. If I had to create a new multidrill config how is that done?
5/13/15       #4: AlphaCam V5 Multidrill ...
You changed machines? Not sure why you would want to do that. The config just gives location of drill spindles in order to call the proper bit based on hole diameter, or to call multiple drills in order to get line or construction holes done using like drills. If you just want to change drill diameters that is done when you call the multidrill macro in the software. It will remember your changes as you are actually updating the .add file. Hope that makes sense. Since we have the same drill block on the same machine, we have used the same multidrill file for 12 years. At some point during the upgrade process, I think it converted .add files to .mdb, but I can't recall.
5/14/15       #5: AlphaCam V5 Multidrill ...
Matt Middleton
Mike thanks for helping me out. Our original machine crashed is why I ran into this issue in the first place. I had all the necessary files it was I had to install the productivity pack to be able to use them. I had a vanilla version of alpha cam without the add ins. Once installed I was able to use the add file I had backed up on the server. The original pc was setup 10 years ago before my time and that employee no longer works here. I can't get support from alphacam but I was able to get a tech from anderson to help out. All is good. Thanks
5/14/15       #6: AlphaCam V5 Multidrill ...
Good deal as long as your XP machine works. I don't think that version will go onto a Windows Vista or higher O.S. so keep a copy of XP or Win2000 handy in case of a future crash.
