Computer Aided Design
Subject: Re: Cabinet Vision Mat Schedule
8/20/15
Cory Member
I accidentally deleted a schedule. I was wondering if I could somehow get it back. I've tried recreating it and its just not working
correctly. Any help is appreciated.
8/21/15       #2: Cabinet Vision Mat Schedule ...
Joe
Did you ever create a back-up of the material schedules?
I only ask because I know we're good about backing up jobs and construction methods...but not the material schedules.
You have my condolences...
8/21/15       #3: Cabinet Vision Mat Schedule ...
Cory Member
Not sure, I'm new to this position. The draftsman quit and I took over. I do have software on another comp. Can i just copy the database folder from that comp over this one?
8/21/15       #4: Cabinet Vision Mat Schedule ...
Joe
Yes...you should be able to do a back-up from the 2nd computer...put it into the "back-up folder" that CabinetVision creates, and then pull from that folder into the computer with the missing schedule...once you update it, the missing schedule should be there. (Provided it was the same set-up as you originally had on yours.
8/21/15       #5: Cabinet Vision Mat Schedule ...
Joe
You can double-check with Cabinet Vision, but if you only check the material schedule box for the back up and update...that is the only item that will be affected. At least, that's how we update our construction methods without affecting the different jobs we have saved between 3 computers.
Good Luck!
8/21/15       #6: Cabinet Vision Mat Schedule ...
Cory Member
Thanks Joe for the replies,I was able to figure it out and everything is back on!
8/21/15       #7: Cabinet Vision Mat Schedule ...
Joe
Outstanding!
9/20/15       #8: Cabinet Vision Mat Schedule ...
Nite
Check the automatic backups folder,,,email me if you need help
number000073@gmail.com
