Computer Aided Design
Subject: Re: Alphacam nesting issue
9/24/15
Pdub
I'm trying to nest a bunch of random parts and the nester keeps putting some of my parts WITHIN other parts on the sheets. I'm using the original nester on Ultimate 2013 v1 (don't ask me why the other "newer" nester won't work).
Anyone have any ideas?
9/27/15       #2: Alphacam nesting issue ...
Mark
If you are nesting geometries that are not fully closed this happens. In other words open geometries are gibberish to any nester. You may have a small gap at a corner or overlapping curves that appear closed but are not. Try control G (ghost tools) to analyse.
Also in nesting tool paths or geometries and tool paths you need to be sure all closed geometries have tool direction set to outside or center. If they are set to inside this happens when toolpaths are present since the inside of a toolpath allows use of waste. For example if you cut out a counter with a sink hole in it the nester wants to put anything that will fot inside the waste that is the sink hole. Also if you have a closed geometry but it contains an open line that crosses outside that closed geometry. This is viewed as an open geometry.
These nesters both preform very will with the expected input. I have found the new nester is better than the old many times, but not always.
9/29/15       #3: Alphacam nesting issue ...
Brian T
once you go into the nesting options box select prevent nesting in apertures. This will stop objects with different perimeter tooling from having smaller parts nested within them.
9/30/15       #4: Alphacam nesting issue ...
Pdub
Mark, it's actually doing it with all closed geometries.
Thanks Brian, but where do I find that option? I'm not seeing it.
9/30/15       #5: Alphacam nesting issue ...
Brian
I use the newest version of standard router but I believe the nester in ultimate is the same.
After you select your parts to nest, you select your sheet to nest into , then the next page is nesting parameters . On the right hand side is the box that say's special functions. There are about 15 functions you can choose from to adjust your nests. I use them in every nest as my parts are always different and require different functions for the best yield. Select prevent nesting in apertures. That should resolve your issue. If not there is another way but you would have to contact alphacam for that one. It was explained to me but I never needed it as the apertures works every time for me. For me there service has been great. I usually get a call within the hour .
9/30/15       #6: Alphacam nesting issue ...
Pdub
Bummer. Must be a new feature. I also have 2014 R1 Essential and that option isn't there either.
9/30/15       #7: Alphacam nesting issue ...
Brian
You may have to do a manual nest. Or nest separate parts on individual sheets.
I believe there is a video of manual nesting on youtube
9/30/15       #8: Alphacam nesting issue ...
Pdub
Yes, wound up doing a manual nest. It was a PITA so I'm trying to avoid doing it in the future.
Thanks for your help.
