Computer Aided Design
Subject: Re: dxf to biesse works for boring
1/4/16
antony Member
how to make a dxf to import to biesse works for boring
1/7/16       #2: dxf to biesse works for boring ...
mike  Member
Website: http://www.lustigcabinets.com
you need to manual import dxf as geometry and the apply operation as geometry.
1/19/16       #3: dxf to biesse works for boring ...
Nite
AutoCAD is a must in CNC or any drawing type,,,consider getting alphacam with the correct post processor,,,this will output machine specific nc code and all you have to do Is plug the usb stick into the editor and run it
1/20/16       #4: dxf to biesse works for boring ...
Jason Scott
Do you know how to do a manual import?
Once you open a manual import you can import the circles as either geometry or as a boring operation. It's probably simpler to do it directly as a boring operation.
Hope it helps
4/28/16       #5: dxf to biesse works for boring ...
Kevin Member
Anthony
A .dxf file is created with using an CAD software such as Auto CAD. There are others. Using the software you can create drawings of lines and circles to create the part(s). The image is then exported to a separate folder on your computer. I would normally copy and past to a blank file prior to saving as a dxf. This removes the stray lines that confuse the process.
Once it is saved as a dxf file, you can then import the file as mentioned above. Cad software is necessary.
7/12/16       #6: dxf to biesse works for boring ...
david wishengrad
TCHB2W0D7510
7510 is the depth of the bore, including into the spoil board. Set as needed.
TCHB8W0D7500 is the bounding box of the overall part with .75 thickness
TCHB1W0TCD$11$S18000F20000TC2D7510 is outside toolpath of overall part.
11 is the tool number
18000 is spindle speed
20000 is feed rate is mm per minute
7510 is the depth.
All geometry must be 2d polylines or circles.
Vertex order seems to matter for direction.
