Computer Aided Design
Subject: Re: enRoute software
enRoute software
4/6/16
Sean Member
Any enRoute software users out there?
I'm looking for the pros, & cons on it for a future purchase, we do from standard casework to very custom conference tables, die walls etc. Just looking for honest answers. Thanks!
4/15/16       #2: enRoute software ...
Steve Guenzel
I used Enroute for years, switched to Aspire 8, so much better and easier to learn and use
4/17/16       #3: enRoute software ...
Benjamin
I'm an Enroute fan. Great product, great service, they are always innovating. There's a new release coming any day if it's not already out.
Last time I checked Aspire does not have drill block capacity, so check that out. Otherwise I cannot compare to ER.
Enroute's ATP function applies tool paths to DXF parts imported from a parametric cabinet software, so you will need another software for that. I use Wood Cad Cam which I think is by far the most powerful and versatile solution available. WCC does both casework and custom one-off creations, but there are many others that work with Enroute. I set up the Auto tool path to perfection with custom tweaks and improvements as I go along. You are in control of all parameters. The learning curve for Enroute is not a breeze, but in IMHO it's worth it.
6/11/16       #4: enRoute software ...
Jason Scott
I use enroute all the time. Very powerful software.
They have a you tube channel you can go look at to see what you can do with the software and they walk you through creating different files.
My only complaint is that there in not the option for parametric programming.
I use biesse works and enroute for different things because of that.
7/7/16       #5: enRoute software ...
Luke Member
EnRoute 6 Pro is now available as a subscription for $89/month. This is the full all-inclusive version with 2D, 3D, Textures, and Auto Tool Path.
