Computer Aided Design
Subject: Re: Alphcam lead leads question
8/27/17
Ian Member
I have been working with Alphacam on a limited basis for the past couple of months. I grasp the 2D design aspect, but I don't have a full understanding of the lead in /lead out feature. I have not had any crash type issues, but sometimes my cuts don't turn out right- there is a small amount of stock at the beginning/end meeting place of some profiles, and others seem like the tool is coming off the workpiece way too far between cuts. Any advice would be helpful as the manual is not totally specific.
8/27/17       #2: Alphcam lead leads question ...
Ian Member
I am pretty much after being able to have the tool come in and out exactly where I want it to, in the direction I want it to, but don't understand how to accomplish this
8/27/17       #3: Alphcam lead leads question ...
Mick Folan Member
99% of times i click on line leading in then line leading out and I usually have the default settings set to 8 times radius of tool (seems to work for me), I hit auto, and on the bottom bar either select ALL or manually select the toolpaths, right click and youre ready to go.
the 1% I go manual is when like I'm cutting the inside of a circle and the lead in /out is going to damage the part I select the tool path at the arrow which is the start point and manually pull out lead in/outs.
Any clearer?
8/27/17       #4: Alphcam lead leads question ...
Ian Member
What do you mean manually pull leads in or out? Not familiar with this
8/28/17       #5: Alphcam lead leads question ...
MIKE
here u go there is alot of help in alphacam u can get from this person. he puts a ton of alphacam help online even for the beginners. alphacam doesn't want to help users like many of the other software co's do. good luck mike
https://www.youtube.com/channel/UCMDxOMPPh5i92Bahyg8BbdQ
8/30/17       #7: Alphcam lead leads question ...
Mick Folan Member
What I mean is, and its difficult to put into words, when you click on the arrow on the toolpath it kinda sticks to the cursor. You can manually move the start point to an optimum location( that is your lead in) then you move the cursor to an optimum point away from the start point( that is your lead out)
8/30/17       #8: Alphcam lead leads question ...
Ian Member
excellent, great info, thank you
