Computer Aided Design
Subject: Re: CV Issue
CV Issue
8/31/17
Stewart Member
Okay, I am still using CV 9 and S2M ultimate (latest version). There is a false front piece I commonly mill that has four 8mm holes for my adjustment screws. It's just a simple drilling operation and I've done it many times but all of a sudden, it no longer selects the 8mm bit in the drill bank. It just takes whatever bit is already in the main spindle and plunges it into the board - doesn't even turn the spindle on. My engineer and I have looked through all the settings - everything looks normal. We cannot seem to figure this one out. Has anyone got ideas of how this would even happen?
Thanks in advance, Stewart
8/31/17       #2: CV Issue ...
cabinetmaker
Make sure the tool catalog in the post matches the tooling table in the machine
Then make sure you are setting the limiting reaches of the boring head to the limitation of the machine as in depth in Y and X
seems to me it's picking up a cutter to hit a spot where it thinks the drill cannot reach per CV
1/26/18       #3: CV Issue ...
Chevy
Check to make sure your drill block is set up properly in the machine tab
