Computer Aided Design
Subject: Re: AutoCAD 2018 hatch question
12/3/17
Mikhail Member
I just upgraded to 2018. Now I have the problem with hatches. No mater what i do I can't get the grips working on the hatch pattern. Even when I dissociate the hatch from it's boundary I still get one single blue dot in the middle. GRIP variable is set to "2" so technically all corner and mid grips should show up. All other object grips work just fine, problem persists with hatches only. Did anyone have this problem with 2018 or other versions of AutoCAD?
12/18/17       #3: AutoCAD 2018 hatch question ...
steve ayars Member
when the hatch window is opened look under options and make sure the annotative and associative are unchecked. and see if that works.
12/18/17       #4: AutoCAD 2018 hatch question ...
Mikhail Member
Both annotative and associative check boxes are unchecked, but it still does not work.
12/18/17       #5: AutoCAD 2018 hatch question ...
steve ayars Member
Type in hplinetype and see what it is set to
12/18/17       #6: AutoCAD 2018 hatch question ...
steve ayars Member
also check GRIPMULTIFUNCTIONAL
mine is set to 3
12/18/17       #7: AutoCAD 2018 hatch question ...
Mikhail Member
It is set to "off" but setting it to "on" not changing anything.
12/18/17       #8: AutoCAD 2018 hatch question ...
Mikhail Member
mine too is set to 3
10/27/18       #9: AutoCAD 2018 hatch question ...
Don Caron
Re: Hatch Grips
After picking the grip, press CTRL to cycle through options (stretch, add vertex, and convert to arc). You should be able to see these option if you just hover your cursor over the grip without click the button.
