Computer Aided Design
Subject: Re: Modifying v67 repots
6/12/19
Ex-Pat Member
I need to modify a Microvellum v67 report. I want to filter out the shelf clips from the hardware report - they are a supply item, not purpose bought and it adds pages to the hardware report. I have modified reports long ago but have forgotten and of course v67 now basically being heirloom tech I can't find any instruction videos on line anymore. Can someone please point me to where you can add and modify filters? TIA
6/13/19       #2: Modifying v67 repots ...
Gary Balcom Member
Pat,
If you don't want them to show up on the reports, go into the cutlist (product or subassembly), and make it so the hardware name ends up with a negative symbol in front of it, like -ShelfClip. You can do this with the following formula if it's a pointer:
="-"&M!Pointer
Ideally, you do this through library designer.
you may also be able to change the hardware pointer for the shelf clips in the material file, by changing the material name to a -ShelfClip. It's been to long to remember if that will work. If it does, it's a 2 minute job.
6/17/19       #3: Modifying v67 repots ...
Ex-Pat Member
Yep, the negative material type in the hardware list will do it. As is often the case, I blew right past the simple solution and made it complicated. Thanks a ton!
