Computer Aided Design
Export csv file to CAM software ?
12/15/13
ozan
i am looking CAM software that imports csv files and builds all the cabinets back in 3D graphic is preferable , than gives me option to construction methots for dowel construction, and then post prosesor any pt to pt. also preferable . I am not intrested cad design software , or redraw or type the design to do that , I will provide any path csv format or DXF but no machining on it . Does anyone knows something like this?
thanks
ozan
12/15/13       #2: Export csv file to CAM software ? ...
Kenneth
Cabinet parts pro will import a csv file and it's not very expensive. I don't know of one that will turn a csv into 3d though. It does output machine cut files.
12/16/13       #3: Export csv file to CAM software ? ...
yaakov katz
if i understan you
for example biesse nest(plugin on BSW)
can get the csv files with all the instruction and path for the programs
and create the compeate job
12/25/13       #4: Export csv file to CAM software ? ...
Ozan
Yes cpp imports overall dimensions of the cabinet, then you need to re-consturct the cabinet parts, It is great software and $250
note: not sure how much customization you can go with it to re-construct the original cabinet again and not sure how well post processor written but it close.
Yaakov
Is Biesse Nest plug in on Bw can output *CID format, ? does any body knows how much Biesse work software ?
12/25/13       #5: Export csv file to CAM software ? ...
yaakov katz
Yes biesse nest can export cid
Actualy its create the bpp file but bsw can export cid cix dxf and iso
Biesse nest can also get cid files to create nesting project
