Computer Aided Design
Cabinet Vision Toe
2/15/14
bob
Can somebody help me with inserting Finish toe in cabinet vision.
I trying to insert in finish drawing toe that will show in 3-d drawing
Any idea how I can do that ?
2/16/14       #2: Cabinet Vision Toe ...
Joe
Bob,
I have created a part called Finished toe that I use as one long piece to cover a row of cabinets. When need it, I bring it into the ortho view and manually add it to one of the cabinets in the line and then adjust it's length to extend over connecting cabinets. This way my cut list shows a rough front toe and one long finished toe.
If you know how to add a part, and are comfortable with using object intellegence to position the part, this works well. If you do not know either of these things, it's something you need to learn first.
I have seen a UCS on the cabinet Vision Forum that someone shared that does this automaticly.
If you don't care about having it on your cutlist, and only want the cabinet to appear to have a finished toe, Use the construction wizard to extend the front toe to touch the adjacent cabinets.
Hope this makes sense.
2/16/14       #3: Cabinet Vision Toe ...
Bob
I need just for 3-d drawings
Toe we cut manually from material what we have left from CNC cut off
2/16/14       #4: Cabinet Vision Toe ...
Joe
You should be able to set a material for the front toe that will match your exterior finish.
Then use the assemby construction method to extend your front toe in front of whatever end type you are using. Even add some to them if you need to make up for a scribe.
Only problem is your cutlist will be off for the front toe size If you don't want to build your cabinets this way.
2/17/14       #5: Cabinet Vision Toe ...
PWW
If you just need it for visual purposes you can create a molding profile and just draw it around your toe boxes.
We do this for clients, and then I have a toe skin object that is just an 8' rip, height adjusted, that I add as an order entry and bump the quantities to what we need so that they get machined.
