Computer Aided Design
MV Perfect Grain Question
3/6/14
Steve
I was making changes to our basic ADA angled cabinet. Why is it when all I did was change the angle of the panel and also the length of the panel it will not nest when the perfect grain is on. When I turn it to 0 in the properties it will nest just fine. How ever it does nest the width of the panel length wise on the nest. Any suggestions are much appreciated
3/6/14       #2: MV Perfect Grain Question ...
Scott R Smith  Member
Website: http://www.caseworkcadcam.com/
What version of MV are you using?
3/8/14       #4: MV Perfect Grain Question ...
Jack Webb
Because Toolbox cannot handle both irregular shapes, grain direction and nesting at the same time. They need to work on the whole nesting feature as it is not all that good in comparison to other applications. I have been using it and doing workarounds for years.
3/12/14       #5: MV Perfect Grain Question ...
I have a very custom ADA w/ removable panel product that I spent more time on then I care to think about. I ended up doing the removable panel as a subassembly, and I thought the machine points and origins may be the reason perfect gain works right. So if you want to check it out, here’s a V67 job folder with the product in it. http://www.caseworkcadcam.com/ADA-V67-JobFolder.zip
