Computer Aided Design
what soft ware needed
4/25/14
Akram Member
Website: http://www.americanvisioncabinets.com
Hi,
we are so new at the cnc world, we just go the 1st one and waiting for the initial setup.
we have KCD cabinet builder which is the basic. we are considering either upgrade and pay around the 7.5 k to get it to the cnc OR start with Mozaik month to month which Yes they have a post for it to fit our cnc.
the question is Do we need other soft ware such Alpahcam or Enrout to use the cnc for cabinet parts? i was told that Mozaik does not need any ad ons for the machine to start cutting.
and if any other software needed please advice which on is the simplest and fast self study.
Thank you
4/25/14       #2: what soft ware needed ...
JM
You can get the KCD dxf output for about $4k then use vcarve pro or cabinetpartspro to do the nesting and toolpathing. Vcarve pro and cabinetpartspro are both extremely affordable......well under $1k
The extra $$$ for the one button machining in KCD is a watered down version of enRoute that runs in the background. You are far better off using a separate CAM package outside of KCD as you will likely need the CAM package for other stuff anyways.
I am currently going through this myself. My new router is expected in about 4 weeks. I debated to switch to Mozaic from KCD, but decided to stick with KCD. I have not used mozaic, but have been told that creating presentation drawings and the like can be a little tedious.
Rent Mozaic for a month and give it a try.
4/25/14       #3: what soft ware needed ...
Just got a cnc in January. I had been using Kcd for over 10 years and love how easy it is to use. I almost spent the money to buy the cnc add on but decided to try Mozaik first. It made sense to try it before I spent the money on the kcd add on. So far Mozaik is working out good. It isn't as easy a kcd but much more powerful. You can do more custom cabinets with it.
You will want other software like Vcare to do other things with your cnc but if you just want to do cabinets then mozaik is all you need.
I would recommend at least trying mozaik for 3 months first.
4/26/14       #5: what soft ware needed ...
Akram
Thanks for all the responses, so many people recommended vcarve pro for more than just cutting cabinets. i have used Kcd over 4 years now it is so easy to learn and free customer support but has some Limitations such as for example turning. base door cabinet to 4 drawer cabinet and also equal size drawer height with some simple clicks . I Will Call mozaik and will give it a try.
thx
4/26/14       #6: what soft ware needed ...
JM
Scott,
Can you give an idea of how much more tedious Mozaik is over KCD....
How much longer to draw a typical kitchen?
How much longer to create presentation drawings?
Any quirks that are tough to deal with?
Do you use the pricing module?
How long did it take you to get proficient with it?
4/28/14       #7: what soft ware needed ...
JM, those are loaded questions to someone that is still learning it. Part of the learning is also the fact that you are producing parts on the cnc and how you used to do something one way can now be done differently on the cnc. It might take me twice as long to draw. Some of it will go quicker once I make some other library cabinets. The presentation drawings are sent right over to Sketch up so there isn't much to do with them, although there is a lot you can learn to do with them in sketch up that I haven't learned yet. It's lacking some shop drawing stuff that I think they are working on. Probably the hardest thing to learn is how to set up things to build the way you want to but you can get a lot of help from them on that. I don't use the pricing part of it yet. I am not proficient with it yet. The best part of Mozaik is that you don't have to spend a lot of money to find out if it works for you or not.
Hope that helps some.
5/2/14       #8: what soft ware needed ...
Evan Member
Website: http://www.near-west.com
JM,
Be aware that if you want to make a decent submittal scaled drawing with a title block, you will need SketchUp Pro, which is about $600. Mozaik uses SketchUp for its 2D and 3D rendering, which is clever, but there are about 10 steps to create each drawing, plus you will have to add most of your dimensions and annotations manually.
For the price, Mozaik is a good option, it can do a lot more than KCD. I certainly didn't want to pay the big bucks for the KCD CNC module so I switched. We only use Vcarve for the oddball stuff, like setting up boring patterns for Tandembox drawer fronts. Vcarve is excellent, although if you want to do 3D toolpaths you will need to upgrade to Aspire.
5/6/14       #9: what soft ware needed ...
Chris McVey  Member
Website: http://www.brega-tech.com
What about renting autocad?
A new program they are doing, no, cannot vouch for it, but something very much worth looking into possibly.
AutoCAD rental
