Computer Aided Design
2 pc MDF doors in Cabinet Vision
9/16/14
Bob Member
Is it possible to make 2 pc mdf doors in Cabinet vision?
I was thinking about use glass or ¼ panel for center
Any help will be appreciated.
View higher quality, full size image (500 X 340)
9/17/14       #2: 2 pc MDF doors in Cabinet Vision ...
Darren Member
Bob,
I use a UCS to create 2 routes on the door. 1 for the rebate & 1 for the cutout. Also Attributes on the side to adjust Stile & Rail sizes & rebate depth on the fly. Also I have a part added for the glass in the UCS
What version of CV solid do you have.
9/17/14       #3: 2 pc MDF doors in Cabinet Vision ...
Bob Member
I using version 8 ultimate
I want to be able to create separate frame and panel and put together after. That will on end looks like 1 pc door
9/17/14       #4: 2 pc MDF doors in Cabinet Vision ...
Darren Member
Bob,
You could use door maker in your Door Catalog Editor to make the door you want.
You would have to setup a tool set to machine the rebate etc. Google Cabinet Vision Solid Door Maker for videos on how to do this
9/17/14       #5: 2 pc MDF doors in Cabinet Vision ...
Bob Member
I allready make mdf door and but is 1 pc door . But I was thinking to make frame ( glass ) door with 1/4 panel inserted and send everything to CNC . But some how panel is not showing in optimisation
9/24/14       #6: 2 pc MDF doors in Cabinet Vision ...
Bob Member
Is any software recommendations for 2 pc MDF doors ?
9/25/14       #7: 2 pc MDF doors in Cabinet Vision ...
Kerry Fullington
Website: http://www.hightechcabinets.com
We use Panelmetrix.
Panelmetrix Software
9/25/14       #9: 2 pc MDF doors in Cabinet Vision ...
Bob Member
Any idea what is last version and build for Panelmatrix software ?
9/26/14       #10: 2 pc MDF doors in Cabinet Vision ...
Richard
I believe Panelmetrix 7 is the latest Version, not sure what build. But keep in mind Panelmetrix is configured for Thermwood CNC's and to my knowledge it is not simple to configure to another CNC. Just verify that if you are looking into it.
9/26/14       #11: 2 pc MDF doors in Cabinet Vision ...
Bob
I have Omnitech seelex pal cnc
9/26/14       #12: 2 pc MDF doors in Cabinet Vision ...
Paul S
Bob What's the deal ??? I have the MDF door maker from plaint and can make almost anything with the program .
9/26/14       #13: 2 pc MDF doors in Cabinet Vision ...
Bob
Paul
I trying to make 2 pc MDF Doors with separate frame and panels.
Any idea how to do that ?
9/26/14       #14: 2 pc MDF doors in Cabinet Vision ...
Richard
I am a bit confused. Everyone seems to suggest CV can handle the job. Why not just get up to date with support fees and have them set it up for you? It's got to be cheaper and easier than buying and learnig a new software package.
Just a thought.
Richard
9/27/14       #15: 2 pc MDF doors in Cabinet Vision ...
Paul S
Bob if you are running S2M and have the ability to run a 6th face your all set.... But there are work arounds that you could do if you don't...... I use there tech support and its worth every penny ....
10/1/14       #16: 2 pc MDF doors in Cabinet Vision ...
Bob
I am using 6th face with S2M just to make route on back of the door.That way door will look more similar like real wood door.
But, have no idea how to make 2 pc MDF doors with cabinet vision.
Wondering if possible to do 2 pc door in Alphacam ?
Also I am looking for somebody who can give me tech support and how to set 2 pcs doors.
