Computer Aided Design
Trying to draw walls of a CV job in autocad
2/14/15
Im having an issue trying to figure out how to draw these walls from a cv jov into autocad cuz i thought it would be easier if i could do it in acad first, then transfer to cv
As you can see, i have some odd shaped angled walls and some typ. 45 and 90 deg corners
Im having an issue drawing the odd angled walls and then into typ. 45 and 90 degs off of those odd angled walls.
Can someone pls help me understand the math behind trying to do this. I got the 90 deg walls off the odd angles, but that was only from screwing with acad for a while last night and now im just flat out frustrated
2/15/15       #2: Trying to draw walls of a CV job in ...
John
Sometimes I have to send the floor plan to drawing and then use the angular dimension tool to know what the angles are. Then I go back to plan view to adjust.
2/15/15       #3: Trying to draw walls of a CV job in ...
David Wishengrad
Use the buttons at the end of the ucs toolbar. They are rotate x, y and z. You'll only need the the z one.
Rotate the ucs to the angels you have already drawn, then turn on the ortho (F8) to snap 90's off the angled lines.
2/15/15       #4: Trying to draw walls of a CV job in ...
David Wishengrad
I can't upload the dwg here, but here is are 2 pdf's.
It doesn't look like your cv drawing. The second pdf is higher res. I'm not sure if that will help.
ang_Model__1_.pdf
ang_Model__2_.pdf
2/17/15       #5: Trying to draw walls of a CV job in ...
Or can't you just use construction lines?
Just select the construction line icon and then draw you first horiz or vert line, then hit the space bar to repeat the command and this time select Ang and then type in the angle you want and then select the though point.
Or Dave send me the DWG and I will load onto dropbox and Mike can get it that way. If interested let me know?
2/17/15       #6: Trying to draw walls of a CV job in ...
Thx guys.
After my father in law (whos really good in math) came by last night, im even more confused. When i first drew it, i went in a clockwise fashion because i figured the critical part was where the systems are at.
My FIL had me draw it going counterclockwise and so did an autocad friend of mine and what i dont understand is when i drew the wall going up to the left at 140.5 degrees by @(dimension) <140.5, then dimensioned it, it showed it as 129.5. WHY!?!
Because when i drew it clockwise and "winged it", it showed that angle at 140.5.
From what my friend said, it all depends on the direction you're drawing as to where say 270 is at. I dont get it. :-(. Can anyone pls help me better understand this?
2/17/15       #7: Trying to draw walls of a CV job in ...
Mark Member
140.5° off vertical = 129.5° off horizontal, depending on the direction you measure. 270° will vary only if you're rotating or have moved the UCS.
2/17/15       #8: Trying to draw walls of a CV job in ...
You understand that Auto Cad measures 360 degrees.
0 degrees starts at the horizontal line.
Measuring counter clockwise from the horizontal to the vertical is 90 degrees.
If you enter 140.5 degrees it does measure 140.5 degrees from the horizontal line.to angled line.
Does that make sense?
If not just google this question, there are a lot of tutorials and videos about Auto Cad.
2/17/15       #9: Trying to draw walls of a CV job in ...
cabinetmaker
What version of CV are you using ?
2/17/15       #10: Trying to draw walls of a CV job in ...
I get that acad works counterclockwise, but one of what im not understanding is why when i drew the walls in a clockwise rotation and fudged the angles, i got it to show 140.5, but when i drew it counterclockwise and used the angular tool, it showed 129.5. If i did @50<140.5 and did an angular dimension, why wouldnt it show it as 140.5, instead of 129.5 when drawing that wall up to the northwest, vs southeast. Northwest shows 140.5, but southeast shows 129.5. If i think about the 360 degrees, northwest on the "autocad dial" would be correct but if i were going in the southeast quadrant, it would be between 225 and 360.
Have i confused the hell out of anyone else? Lol. Sorry!
2/17/15       #11: Trying to draw walls of a CV job in ...
John
This is about the best I could do.
View higher quality, full size image (1084 X 831)
2/17/15       #12: Trying to draw walls of a CV job in ...
Mark Member
Note in pdf
CV_Layout.pdf
2/17/15       #13: Trying to draw walls of a CV job in ...
David Wishengrad
It all depends on the UCS (User Coordinate System) in Autocad, as Mark pointed out, and not to be confused with the CV UCS (user created standard).
The UCS in ACAD is your framing square that all coordinate and angle input is referenced against unless you specifically tell ACAD to use something else as a reference.
If you put a framing square on a wall so that the 24" side is parallel with the ground and want to draw a line at a 45 degree angle to the floor, you can just rotate the framing square (UCS) 45 degrees.
The line you draw will be at 45 degrees of the floor, but will have a relative 0 degree angle from the framing square.
There are many different ways to do this in ACAD. I suggest you study Mastering Autocad by George Omura.
If you email me I will send you the dwg. You may need to have membership here to email me through a message.
2/17/15       #14: Trying to draw walls of a CV job in ...
David Wishengrad
Just a pic
View higher quality, full size image (638 X 801)
2/19/15       #15: Trying to draw walls of a CV job in ...
Mike you are an ingrate...
6/8/15       #16: Trying to draw walls of a CV job in ...
Tim
CV has an import / export DXF utility - should be easy thing to do.
