Computer Aided Design
Visual issues in Cabinet Vision
2/23/15
I had these issues first pop up after re-installing windows (was working fine prior); I assumed it was a new driver issue and would be resolved with future driver updates. That was a few months ago, I've been using my old (not really old) computer since but now it has started doing it too. Both are newer AMD based computers (cpu and video); it's still working fine on my intel based laptop. I'm not on their support so no help there; I doubt this is an isolated issue so hopefully someone with a similar experience can share the fix.
View higher quality, full size image (1920 X 1040)
2/24/15       #2: Visual issues in Cabinet Vision ...
Adam B  Member
I have the same issue. We just put in a new AMD video card.
On the e-support site the only remedy at this time is to do into control panel, personalization, scroll down to "Basic and High Contrast Themes" and select Windows Basic.
2/24/15       #3: Visual issues in Cabinet Vision ...
Adam B  Member
Sorry, I meant "go" not "do".
2/25/15       #4: Visual issues in Cabinet Vision ...
That worked for my older Windows 7 computer, but it doesn't seem to be that easy in Windows 8 - I've tried the different compatibility modes found in the properties of the shortcut, but no luck yet.
2/25/15       #5: Visual issues in Cabinet Vision ...
Adam B  Member
Mike,
Did you try the compatibility mode in version 7 then change the view to Windows Basic?
2/25/15       #6: Visual issues in Cabinet Vision ...
There isn't a Windows Basic theme like in Windows 7, I've tried the different default and high contrast themes, many combinations of the compatibility settings and any performance settings I could find...still no luck. The computer I got working has a 7870 video card, the one not working has r9 290s...
View higher quality, full size image (1200 X 675)
2/25/15       #7: Visual issues in Cabinet Vision ...
ranliker
Years ago there was a setting, I think in Windows (most likely XP at that time) for hardware acceleration. I remember having to turn it down to clear up some display issues. I'm not sure how relevant that is today. It may be something to check out.
10/2/15       #8: Visual issues in Cabinet Vision ...
Matt Vivion Member
Website: http://www.mvpcabinets.com
AMD display drivers are to blame. If you are running windows 8.1 or older there are several previous versions of the AMD WHQL drivers that will still run cabinet vision. (view on AMD's website : http://tinyurl.com/previousAMDdrivers )
I believe 14.12 and older will run cabinet vision.
For most Windows 10 users however, AMD's previous drivers will not install / run correctly. In this situation, if you disable the AMD display adapter in Windows Device Manager it will make the operating system use Microsoft default display adapter which works correctly with Cabinet Vision.
2/18/16       #9: Visual issues in Cabinet Vision ...
Cody
Using Windows 10, AMD r9 380 4g, cv 9. The fast way I found to fix the issue was uninstalling the AMD driver on my computer. Fixed the problem instantly. This reverts the video driver to the default windows driver. This will still use the vram of your card and its video output. From what I can tell so far, the default drivers feel perfectly stable with cv 9. Hopefully Cabinet Vision can release a hotfix, I would much rather have the latest drivers.
