Computer Aided Design
Hyperthreading on Core i7, running TurboCAD, KCD, causing computer hangups?
1/4/16
Matt
We've noticed a problem on our main engineering computer that we can't explain, and none of us can explain.
When running KCD and TurboCad, and similar programs such as Report Center (True32), the computer will simply "hang up" as if the whole thing is not responding.
I don't suspect it to be an overheating issue, because I've had it happen to me right after waking it from sleep and trying to open Google Chrome (KCD and such were probably running in the background, I can't remember).
Anyhow, I've been cautioned that some programs don't do well with the hyperthreading on the Core i7's.
Our machine has a full 32GB ram, and a 1GB graphics card (I am not sure of the make/model of the graphics card nor the bit rate).
Is it viable to think that the hyperthreading could be choking up on some of our software? We are going to try turning it off to see if that helps, but figured I'd ask there for any experience.
Processor is over 3Ghz, I can't remember the actual model number, but it is a Xeon i7.
Thanks,
Matt
4/1/16       #2: Hyperthreading on Core i7, running ...
Brian
It is either a Xeon or an I7. Xeon being the server class and I7 consumer. There is no Xeon I7.
Really doubt that it is Hyperthreading, but if that is the case it is really not the processors fault but rather applications that do not play well together or a video card issue. The I7 should play well. We have AutoCAD, Microvellum, NC Plot, Outlook, Excel, Internet Explorer, and Epicor running on 4 or 5 of our machines and they are I5's and I3's. I would probably look more at a software issue rather than hardware. TurboCAD? I played with it years ago, I would probably look there first. Who knows.
