Computer Aided Design
Mozaik to Weeke
2/12/16
Nick Cook Member
Website: http://www.cedarrivercabinetry.com
Hope someone can help with this. I'm attempting to run a test part that was created with online help from Mozaik. I imported the file to the proper folder in my Machine Control Center. The file won't run. As a test I selected an existing file from the folder that was in the MCC when I bought the machine. This file works. Is my Weeke not recognizing the test file? The technician helping me said the G-code generated from the test file didn't look familiar to him (looked highly proprietary). Perhaps the Post is wrong?
2/14/16       #3: Mozaik to Weeke ...
cabinetmaker
You are going to have to look @ the post and go line by line to make sure it is correct. Hopefully someone here can walk you through this.
2/15/16       #4: Mozaik to Weeke ...
Frank D. Jimenez  Member
Website: http://www.cabinetpro.com
Here is some code I generated from Cabinet Pro CNC for Woodwop for the Weeke that shows code for a couple of holes, a dado cut, and a part cutout. You may want to compare it with what you have.
[H
VERSION="4.0 Alpha"
OP="1"
O2="0"
O4="0"
O3="0"
O5="0"
FM="1"
ML="2000"
GP="0"
GY="0"
GXY="0"
NP="1"
NE="0"
NA="0"
BFS="0"
US="0"
CB="0"
UP="0"
DW="0"
MAT="HOMAG"
INCH="0"
VIEW="NOMIRROR"
ANZ="1"
_BSX=2463.80
_BSY=1193.80
_BSZ=19.43
_FNX=0.000000
_FNY=0.000000
_RNX=0.000000
_RNY=0.000000
_RNZ=0.000000
_RX=2463.80
_RY=1193.80
]1
$E0
KP
X=53.97
Y=1190.63
Z=44.83
$E1
KL
X=53.97
Y=1190.63
Z=13.08
$E2
KL
X=53.97
Y=682.63
Z=13.08
$E3
KL
X=53.97
Y=682.63
Z=44.83
<105 \Konturfraesen\
EA="1:0"
MDA="TAN"
STUFEN="0"
ZSTART="0"
ANZZST="0"
RK="NoWRK"
EE="1:3"
MDE="TAN_AB"
EM="0"
RI="1"
TNO="3"
SM="0"
S_="STANDARD"
F_="3000"
AB="0"
VLS="0"
VLE="0"
ZA="@0"
HP="0"
SP="0"
YVE="0"
WW="1,2,3"
ASG="2"
RSEL="0"
RWID="0"
MX="0"
MY="0"
MZ="0"
MXF="1"
MYF="1"
MZF="1"
<102 \BohrVert\
XA="130.17"
YA="1012.83"
BM="h166"
TI="12.7"
DU="5"
AN="1"
MI="0"
S="2"
AB="32"
WI="0"
HP="0"
SP="0"
YVE="0"
WW="60,61,62,90,91,92,150,190"
ASG="2"
MX="0"
MY="0"
MZ="0"
MXF="1"
MYF="1"
MZF="1"
<102 \BohrVert\
XA="162.17"
YA="1012.83"
BM="h166"
TI="12.7"
DU="5"
AN="1"
MI="0"
S="2"
AB="32"
WI="0"
HP="0"
SP="0"
YVE="0"
ASG="2"
MX="0"
MY="0"
MZ="0"
MXF="1"
MYF="1"
MZF="1"
]2
$E0
KP
X=765.18
Y=682.63
Z=44.83
$E1
KL
X=765.18
Y=682.63
Z=-0.25
$E2
KL
X=3.18
Y=682.63
Z=-0.25
$E3
KL
X=3.18
Y=1190.63
Z=-0.25
$E4
KL
X=765.18
Y=1190.63
Z=-0.25
$E5
KL
X=765.18
Y=682.63
Z=-0.25
$E6
KL
X=765.18
Y=682.63
Z=44.83
EA="2:0"
MDA="TAN"
STUFEN="0"
ZSTART="0"
ANZZST="0"
RK="WRKR"
EE="2:6"
MDE="TAN_AB"
EM="0"
RI="1"
TNO="2"
SM="0"
S_="STANDARD"
F_="3000"
AB="0"
VLS="0"
VLE="0"
ZA="@0"
HP="0"
SP="0"
YVE="0"
WW="1,2,3"
ASG="2"
RSEL="0"
RWID="0"
MX="0"
MY="0"
MZ="0"
MXF="1"
MYF="1"
MZF="1"
<100 \WerkStck\
LA="2463.80"
BR="1193.80"
DI="19.43"
FNX="0"
FNY="0"
AX="0"
AY="0"
<101 \Kommentar\
KM="WEEKE BHC"
??="0"
2/15/16       #5: Mozaik to Weeke ...
Mozaik Help Desk
Website: http://www.mozaiksoftware.com
No, you do not need to go down the post line by line. The post works great for Mozaik customers (worldwide).
Very little setup involved to link Mozaik to Woodwop, simply map your tools from the Mozaik tool library to Woodwop. That's it.
Most likely this is a tool mapping issue.
If you will return the to the Mozaik Forum you will find responses to your question.
2/15/16       #6: Mozaik to Weeke ...
Gary B.
looks like everyone is right here. I bet it is a tool mapping issue. Also, make sure the output file is a .mpr extension. The technician was half right too. It's not G code, it's Woodwop's own syntax.
