Computer Aided Design
Microvellum Fluid Designer
9/2/16
David Freed  Member
I have read several threads in the forums and knowledge base here as well as other sites on the internet and the only references to Microvellum I've found is the expensive versions related to it working with cnc's.
Does anyone use MV Fluid Designer just to design cabinets and then cut the parts manually? I'm just starting a cabinet shop and the Fluid Designer with the cabinet library looks pretty nice in the web site demo video.
9/5/16       #2: Microvellum Fluid Designer ...
Wood Dust
I don't have experience using microvellum, I sat through one of their online marketing demos but the software was much more complex than what my shop needed . I think many will agree that microvellum is made for large shops doing commercial work . It will have more features in it than you will use or need . You should consider looking at cabinet vision which allows you to buy the drawing software separate from the CNC software , there's also mozaik which offers month to month plans and KDC software . I bought cabinet vision 14 years ago and 3 years ago moved into the CNC world and added their s2m center .
Best of luck
9/5/16       #3: Microvellum Fluid Designer ...
David Freed  Member
Thanks for the response.
I looked at Cabinety Vision. It looks as good as Fluid Designer, but their entry level is $1000. Fluid Designer is free with the cabinet module costing $250. That's why I'm interested in it.
9/5/16       #4: Microvellum Fluid Designer ...
Zach
Website: http://deasmillwork.com
Fluid designer is very good and it intigrates into Microvellum for processing. It is based off of a software called blender. You should contact them and get a trial copy and see if you like it. I have a friend that was using 20/20 and moved all of his retail designers to fluid designer because of the link to MV.
9/8/16       #6: Microvellum Fluid Designer ...
David Freed  Member
Thanks for the info. Fluid Designer doesn't have trial versions. The program is free.
9/8/16       #7: Microvellum Fluid Designer ...
Brian
They cannot charge for Fluid Designer as it is derived from Blender. Look up Blender.org which is an open source project.
1/6/18       #8: Microvellum Fluid Designer ...
Ziyad Member
Does fluid designer even allow machining of the parts. All the videos show it as a design tool with the end product being a nicely rendered image. They have now removed both the free and paid subscription $80/mon version from their website.
Is their a way to get to machining from fluid designer.
