Computer Aided Design
Clipping blocks in Autocad
9/14/16
Dan Cook
Website: http://rdcook.com
I had a way to do this and forgot some steps. I take a raster image of a veneer sample and import it into Acad. Then I could put in a polyline ei. triangle and clip the veneer to the shape of the triangle. Normally I will bring it in in a rectangular shape from the picture. After clipping it to the triangle shape I could do a polar array and create a picture of what a radial match would look like. It was very helpful, however I forgot some of the steps and now can't seem to get it to clip correctly. Any suggestions from you other cad users?
9/14/16       #2: Clipping blocks in Autocad ...
Dan
Not sure what version you use (or if there's a difference) but in '16 it's pretty smooth:
On the insert tab:
Attach - select your image, scale & place.
Draw your boundary and place it.
Clip - select polyline boundary option and select your polyline triangle.
Create array.
