Computer Aided Design
Adding sub-frame to cab in Microvellum
11/8/16
Frank Member
Hello-
We used Cabinet Vision for a number of years before making the switch to Microvellum. And although I do think MV is better in many aspects (S2M, presentation drawings, etc.) I think it is lacking in some friendly capabilites.
In Cabinet Vision you can easily add a sub-frame to your cabinet and create a euro/face frame hybrid type cabinet. Here is a link I found on how it can easily be done. http://www.cabinetvision.com/tips/sub-frame
Was curious if there was an easy way to do it in MV, besides chucking misc. parts on the screen and manipulating and moving them into place, or designing a base starter no box from product starters and placing it over the cabinet. It seems that the MV was designed more for commercial use and is less friendly in the high-end custom millwork area.
If anyone has any suggestions or knows any tricks let me know, thanks.
CV sub-frame easy
11/8/16       #2: Adding sub-frame to cab in Microvel ...
Gary Balcom
Frank,
I've been out of residential for a while, so I'm not really sure what you're asking. Is your goal to have a face frame cabinet, inside some other component?
11/8/16       #3: Adding sub-frame to cab in Microvel ...
Frank Member
Yes Gary, that is basically my end goal.
I pulled it off but not as easily as I would have liked. I'm waiting for an approval and once I get it, i'll post a screen shot to show you what I did, and maybe you could give me a tip on how to do it differently. Thanks for your response!
11/12/16       #4: Adding sub-frame to cab in Microvel ...
Gary Balcom
Sounds good. I'll be happy to take a look at it.
Are you on MV support? There is a good forum available if you are.
11/14/16       #5: Adding sub-frame to cab in Microvel ...
Frank
Unfortunately no Gary that is why I look to forums like these for help and tips. We decided to cancel support a long time ago as we were tight on money. Obviously there are a lot of pros to being on support, but the support wasn't over the top either so we decided it wasn't worth it for us at the time.
11/14/16       #6: Adding sub-frame to cab in Microvel ...
Gary Balcom
OK, I see. What version are you on?
11/18/16       #7: Adding sub-frame to cab in Microvel ...
Brian
Hello Frank, Hey Gary good to see you here too. I can think of a way that I could accomplish that, but my method would require me to do a bit of work in part properties and change a few formulas, not something I would want to do for a one off project. Gary is right in that MV support could probably show you a quick way of doing that. The latest build 15.4.1013 is far superior to any that I have used in the last 10 years along with the 44 libraries.
