Computer Aided Design
Microvellum Specification Group Copy Problem
11/22/16
Frank Member
So I haven't gotten this far into setting up the program until as of recently. Just never got around to it. I set up a master specification group for my paint grade cabinets, complete with correct construction methods etc. I wanted to keep all the settings in there, except change the doors from MDF to Rift White Oak. I simply copied the specification group and re-named it Test. When I changed the material of the doors in the Material File it also changed the doors on my Master copy! Not sure why that would happen, the factory set-up versions are completely different and do not correlate with one another, but the copied one seem to be linked somehow? Anyone have any insight on this subject???? I would appreciate any help thank you!
11/22/16       #2: Microvellum Specification Group Cop ...
Gary Balcom
Frank,
What version and build are you on? you can find this under the help => about menu
11/23/16       #3: Microvellum Specification Group Cop ...
Bob
You also need to create a new material file inside the specification group. I'm not in front of a MV computer, but you can copy and rename the material file. Change your door material in the new material file and make sure it's assigned to the correct spec group.
11/23/16       #4: Microvellum Specification Group Cop ...
Frank
I am using version 14. And thank you Bob, that worked and I was successfully able to get the new specifications to group. I did this by right clicking on the specification group copy and clicking 'Change Specification Group' and changed the 'Cut Parts Record' and the 'Edge Band Record' which allowed me to set-up my own material schedule BUT also keep my Global Settings/Construction methods. thank you. What I find very cool about this feature is you can modify/keep any setting you wish for different instances very easily, after they are set-up in the background of the program.
